Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Modify the Top 25 Interface Resource
dsullinger
We would like to have the interface speed included in the "Top 25 Interfaces by Percent Utilization" view. My thought is to modify the "Top25PercentUtil.Resource" file. I've already modified one of the resource files to meet our needs (01-AllNodes.Resource), but this file I'm making changes to it, yet the changes are not showing up in the "Top 10" view. Am I modifying the correct file?
UPDATE: Since I can't seam to reply to my own post, I'll update this one.
I've since figured out how to do this.
1. I've copied the `SolarWinds\NetPerfMon\Resources\1-2-Top10Lists\42-TopXXErrorsDiscardsToday.Resource` file and renamed it.
2. I changed the `<!-- Title=Top XX Interfaces by Percent Utilization -->` to `<!-- Title=Top XX Interfaces by Percent Utilization TEST -->`. TEST could be replaced with whatever you wanted, since I work for the Arizona Dept of Transportation (ADOT), I generally add ADOT to everything I do so I can search and hunt down my changes easily.
3. Changed `Resource.Title = "Top XX Interfaces by Percent Utilization"` to `Resource.Title = "Top XX Interfaces by Percent Utilization TEST"`
4. Added `Interfaces.InterfaceSpeed,` after `Interfaces.StatusLED,`
5. Added `<td class="Property" vAlign="center" width="4"><a href="")%>"><%=SQLResource.GetProperty("InterfaceSpeed")%></a>">thwack.solarwinds.com/.../View.asp </td>` after the last line of other `<td class=` entries, but make sure you place it before the `</tr>`
6. Then simply selected `Customize Views` and added the new `Top XX Interfaces` list.
Find more posts tagged with
Accepted answers
All comments
mezdem
Is this still the appropriate way to add interface speed to the Top xx lists??
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
