Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
UNIX and Net-SNMP
pmiller
I receive "The Interfaces MIB is not supported on 'Host'" when trying to list resources. If I have the wrong trap name it doesnt connect, nor when I stop the daemen it also errors out. That being said I have to assume its at least trying to connect.
Do I need to configure anything on the NetSNMP to get it to trap the host resources MIB?
Also, if there is already a HPUX SNMP daemon running do I need to do something with it? This is a HPUX 11.0 server.
Thanks in advance,
Paul Miller
Find more posts tagged with
Accepted answers
All comments
BK
Well, on the NetSNMP you would need to configure the community string the agent will respond to.
As for the HPUX SNMP daemon, you probably need to disable it. Two services cannot listen on the same UDP Port.
BK
Nobody Special
Dagwood
BK is correct. You must shutdown the native HP snmp in order to use the Net-Snmp agent.
Let me know how the Net-Snmp agent works for you. I currently use the Snmp-Research Agent in order to monitor with Orion, however I am not overly impressed with the hacked up Installation provided. For $600US each, I would expect to pop in the CD and go. Instead, I must consistently modify their scripts so things work.
What does Net-Snmp cost for a supported version? or are they freebies?
Thanks in advance
mjhamilton
Net-snmp 5.09 works a treat and is free for both HP and SUN servers.. I use it to monitor CPU, Memory and disk plus NIC
No problems thus far
Martin J. Hamilton... lost in a sea of snmp...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
