I'm trying to trigger a TFTP transfer using SNMP. The device I want to backup is a Cabletron SS2210 Menu-based. It would be easier to trigger it with SNMP than using Telnet.
I entered the community strings for my device in NCM. I discovered it and gave me the information in the Discovered Properties.
So what I did basically is set the field Request Config Using to SNMP and left the Transfer Config Using TFTP.
When I started the download it gave me this error: The Device is not a Cisco device,TFTP Host: 10.247.87.34. Device IP: 172.23.0.5
Can the config request by SNMP be done only with Ciscos?
