Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Some Application monitors don't display CPU/Memory
jsanto
I currently have Orion moitoring about 80 processes on several servers. Only about 60 of them show actual CPU & Memory statistics, others only display up/down status. How can I get all of them to show CPU/memory?
Any help would be great.
James Santo
Newland Communities
Find more posts tagged with
Accepted answers
All comments
michael.buskin
The server that you are trying to poll CPU on might not have SNMP enabled or do
not
support the Host Resources MIB Table.
If they do then verify all of you community strings and this should theoraticly work.
// Michael Buskin
// Satelite Communications, Network Management, Network Security
// Optus Pty. Ltd.
michael.buskin@yahoo.com
jsanto
I was able to open the resource MIB for the server I'm targeting in a real-time graph, but in the "All Applications" resource it still doesn't show CPU or memory usage. I verified the SNMP community is correct as well. The specific services that I'm monitoring are SQL server; SQL Agent and Apache.exe.
FormerMember
I am trying to see if the Application monitor is somethign we woudl like to use at my company, we are a citrix Shop primarily, but as of now now matter which server I monitor I cannot see any cpu or mem usage on any machine.. whether it be Windows 2000 server, XP Pro, or Server 2k3 ....
help ?
Oh btw the non existant CPU and MEM usage is only on the applications. the rest of Orion is working ok
billh
Using the app monitor I can get the app memory stats but no CPU stats for that app or any app for that matter. In the App Monitor manager I made sure I had the options selected to collect both the cpu and memory usage. Been running the App eval for 24 hours now and no CPU usage collected for any apps.
billh
Btw, I have the latest patches and just got the eval from sales yesterday so I know that's current also. I just restarted the Orion server for the thrill of it to see if that helps.
jsanto
FYI - Installed the new build and now I get CPU and Memory for all applications. I didn't see anything about that in the release notes, maybe the engine just needed to be restarted. Thanks to all who replied.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
