Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Can't create custom reports or edit existing
FormerMember
Hi everyone,
I'm fairly new to SolarWinds and recently upgraded our copy from 7 to 8. Since then the custom reports that were setup have failed to function. I tried a whole bunch of uninstalling and reinstalling to no avail. I included a link below that shows what happens whenever I try to select new fields in a report. The same error comes up when I try anything under the "Filter Results" tab as well.
As you can see the default queries will actually run but I cannot edit them and creating new reports/queries seems to be out of the question right now.
Has anyone seen something like this before?
s92812220.onlinehome.us/untitled.JPG
Find more posts tagged with
Accepted answers
All comments
jtimes
Did you update the Report Schemas?...
Tricky little bugger gets me every time...
Bring up the Custom Property editor on the Orion server
Right click on the grey area just right of the Help question mark on the top tool bar
Select Customize, then the Commands Tab
Scroll down to Update Report Schemas and drag it up next to the question mark on the tool bar
Close the Customize screen and then click on the Update Report Schemas icon...
This only has to be done when you change versions of Orion, but I usually forget until a report tries to run... (STILL!!!)
John J. Times
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
