Do we have any built in APIs in NPM, NCM, Traffic analyzer which could be used for integrating the tool with other tools/UIs?
Thanks & Regards,
Sumit
Can you provide more details on the use-case?
Hi Chris,
I am looking to develop a web portal which would be single point of login. It would provide the required interfaces/details from NPM, NCM etc based on the user credentials. For example if the user has the credential of a broadband user, based on his login he should be provided the filtered details of his usages/throughput etc. I don't want the user to see solarwind interfaces etc.
Regards,
This should be possible today through the Orion website using node limitations and account view limitations. In fact, we've got a lot of MSPs using Orion in this way. Have you already explored using Orion's included website for this purpose? If so, what specific use-cases are you not able to achieve?
I just want to make sure you're not investing in something we already do out of the box.
Thanks for the info Chris.
I wasn't aware that Orion website itself offers thode functionalities! I'll explore it further.
Could you please help me with some documentation on the same?
Cheers,
In the same lines a specific use cases is; we are looking for a Northbound API for NPM, NCM and NTA to integrate with Higher level NMS such as HP ov or NetCool or NetAssure.
To cater to this need is there a standard northbound interface? If not what are the suggested method to interface with higher level NMS.
Prashant K
