Kindly help me to investigate why a HA failover happened.
have you looked in the message under events there should be "HA Pool Failover" event type, usually that will say why the failover occurred.
Also you can look in the logs, I believe they are located C:\ProgramData\SolarWinds\Logs\HighAvailability
