Hello,
I have a question:
when installing an additional polling engine, it must be the same version as the primary NPM server?
In the admin guide I didn't find anything about this matter.
Best regards,
Daniele
Daniele,
I'll make sure this requirement is more clearly stated both in the NPM Administrator Guide and in the NPM release notes.
Basically, Yes.
You buy a 10.0 NPM and then you use 10.0 additional engines.
Each version increment makes updates to the SQL table structure and so they must all be at the same version.
Regards,
Robert
