Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Cannot start syslog Daemon, Port 524 is in use
ollakal
I installed Solarwinds.and try to run the Syslog server, I am getting an error " Cannot start Syslog Daemon, port 514 is already bound to another process. You will not be able to recieve syslog messages but you will still be able to search the database and send syslog messages" How do I chang the port.
Raghu
Find more posts tagged with
Accepted answers
All comments
Bryan
First of all you need to identify what else is already using that port. You shouldn't need two syslog type applications running on the same system. I use two but they are are different systems for redundancy. I don't believe that the Solarwinds application allows you the option of changing that port used for syslog. In fact on cisco's equipment doesn't allow you to specify a port number, just a server IP address. If your running the server edition of Windows, I believe it has a syslog service built in. Maybe you need to go into the services panel and disable it.?? Hope this help!
Lockheed Martin
Atlas V Launch Operations
Network Engineer
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
