Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
NPM Graph Question
jimin8r
Hi all! I usually like to keep two or three graphs up throughout the day, and I noticed that whenever they update the scale will revert to some default (not the same default on each graph, though). When I change the scale (so, for example, our T1 connection to Birmingham and our T1 connection to Atlanta will show the same scale - easier readability) to something similar, they revert back to whatever the default is (one of them is 10Mbps and the other one is 2.1 Mbps). How can I fix it so the scale does not change every time the graph data updates?
Thanks!
James
Find more posts tagged with
Accepted answers
All comments
DonYonce
James,
The charts will autoscale based on the maximum values displayed. Although you cannot set a fixed scale by interface, you can change the scaling threholds that are used by all graphs.
Edit the scaling.cfg file. It is an xml file that can be edited with any text or xml editor. If you delete the lower scales, it will not use them.
PS. I'll also ask the development group about setting fixed scales by chart.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
