Hello. I've tried to install the the update on two different test machines running Windows 7 Professional SP1 64-bit OS, 4GB RAM, Internet Explorer 11.0.9600.18499, and Adobe Acrobat Reader DC 15.010.20056. The update fails and the logs show the following errors:
AppsInUseSilentAbort = A process is running that cannot be shut down by Setup. Please either close all applications and run Setup again, or restart your computer and run Setup again.
Property(S): AppsInUseUnknownAcrobatApps = Applications that are using Adobe Reader or Adobe Acrobat
ERROR_MIN_OVER_BIG = Setup has detected that you already have a more functional product installed. Setup will now terminate.
ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): IsMinIE_Message = requires Internet Explorer 7.0 or greater. Please visit www.microsoft.com to upgrade Internet Explorer.
LC_UNSUPPORTED_OS_1 = This application cannot be installed on this operating system
Property(S): LC_UNSUPPORTED_OS_2 = Setup will now terminate. Please refer to the minimum system requirements at http://www.adobe.com/go/reader_system_reqs.
Anyone else seeing this problem with this update?
