Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Alert web post-get action orion
antoniod
Anybody knows how is the way to configure the body to configure web post action in a web page?
I´ve had been watching the source of the html code to find how can I get the body of the triggered alerts. but I can´t see in the html code how is the data get to print in the web page.
I need that every time that an alert is triggered send a pop up message and as second action post this message in my intranet web page---
I hope that anybodu can help me thank u!
Find more posts tagged with
Accepted answers
All comments
Isaac
Hi there antoniod,
If I am understanding your problem correctly it sounds as if you would like to place something on a web page and send a pop up message to the console of the Orion server every time an alert takes place.
It should not be all that difficult to achieve both of these goals. For any alert you have configured in the Orion systems manager you can take the following actions:
Send and Email / Page
Play a sound
Log the Alert to a File
Windows Event Log
Send a Syslog Message
Execute an external program
Execute an external VB script
Email a Web Page
Change a Custom Property (in the Orion database)
Text to Speech output
Send a Windows Net Message
Dial Paging or SMS service
Send an SNMP Trap
Get or Post a URL to a Web Server
I hope this helps.
Be fantastic.
p.wiltonjones
I am having the same problem. I am trying to configure Orion Network Performance Manager to raise a ticket in my helpdesk program if a node goes down.
It seems the most appropriate method to do this is to Post a URL to a Web Server but I cannot work out how to configure this as it does not seem to do anything.
I have configured it as follows
1) Use HTTP POST
2) URL when Alert is Triggered -
www.helpdesk.ctac/post_alert.php
3) Body to Post when Alert is Triggered - This is a test
The post_alert.php page simply has a query that says
"INSERT INTO test_table VALUES ('TestNode','TestStatus')"
If I open this page manually (in the web browser) it raises a test ticket, however when I run a Test Alert nothing happens.
I have tested that my Alert has Test Triggered by giving it a seccond event of 'Log to File' and this adds the Test Event to the file.
If anyone can suggest how to make this work, please can you let me know.
As a Temporary work around, I have used suggestions from
www2.solarwinds.net/.../topic.asp
which does work
Thanks in advance
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
