Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion 7 upgrade & maps
dhutchings
Hi there - I've recently upgraded from 6.4 to 7, and everything works fine with the exception of maps. Is there any way to convert my old maps? I spent a fair amount of time creating the ones I've got and I'm not really looking forward to redoing them all again for v7.
Darren
Find more posts tagged with
Accepted answers
All comments
Network_Guru
There is a map conversion utility built into Map-maker.
File > Import > Older versions.....
-=Cheers=-
NG
rpereda
Is there a way to import maps from lets say Openview or any other apps. We have Visionelle, Visio, and HP NNM maps. We have a couple other maps available, but the above mentioned are the most complete maps.
Thanks in advance.
RP
Network_Guru
About the only way to do it, is to save your other maps as .gif files, then use them as backgrounds in Mapmaker. Visio allows you to export a drawing directly as a .GIF file.
For the other programs, you may have to take a screen shot and them convert the .bmp to a .GIF file after cropping it to size.
Create a new map and select this .gif file as the background.
You can then drag the nodes and interfaces onto the appropriate spot on this background.
The problem with this is if your network architecture changes you have to start all over again as the background cannot be easily edited to reflect these changes.
If you use the new drawing features of Mapmaker, you can edit the map directly with
new/changed nodes and links without having to redraw and repopulate the whole map all over again.
-=Cheers=-
NG
dhutchings
Great, thanks a lot, ng. Should have opened my eyes a wee bit more before posting.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
