Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Question about Bandwidth Monitor
DonaldFrancis
This might be a stupid question but here it is. Bandwidth monitor shows utilization in out% and in%. Does that mean that to calculate the total utilization of your line you add the 2 so that if in% and out% were both 25% that would mean your line utilization is at 50% ?
I assume that to be true but I see in Bandwidth monitor many times in which in% and out% are 100% or past and that is with the bandwidth settings correct.
Any help would be appreciated..
Donnie
Find more posts tagged with
Accepted answers
All comments
Network_Guru
It all depends on what kind of circuit you are monitoring.
It it is a half duplex circuit, then you are correct in your calculations.
If it is capable of full duplex, then there are 2 ways of calculating this.
If you are a Network Sales person you would just double the half duplex bandwidth;
i.e. tell your customers their 100mbps FDX switch port is actually a 200Mbps port
(in fact certain switches use this figure when you discover the port with SNMP).
In real world terms you would add the in & out percentages and divide by two for a full
duplex circuit. The percentages shown by NPM are for one direction only assuming the
bandwidth statement applies to each direction (you can adjust these for asynchronous circuits).
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
