Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Problems with node and interface detail
Zer13
We are evaluating Orion 7 and when we open the node details page in the "Min/Max/Average Response time" we see the CPU load gauge (in any node). We have the same problem with the interface detail for any node, for exmple in "Min/Max/Average Bits per second" We see memory used, in "Average bits per second" we see RECV % Utilization, etc.
We have checked all the configuration and there is no mistake. In the Orion Network Performance installed in the server (Windows 2000 Advanced Server - SP4) all is running fine.
Thanks for your help.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Try re-running just the "Install Web Site" part of the Install Wizard.
Exit the wizard when this is done.
You can also change the default views you see for node details using the Web Admin
account and selecting "customize". Find the 'node details' page and select "edit".
You can add/remove any chart, graph, gauge, report, etc. to this page, as per the admin guide:
www.solarwinds.net/.../Web_Administration.htm
Thats about all I can suggest, as I have not used the Orion V7 Demo software...
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
