Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Domino 6.x on w2k sp4 memory reporting issues
mjhamilton
Anyone found a fix for the issue wil servers running Lotus Notes Domino 6.x on Windows 2000 SP4 reporting silly memory usage....
Mine report 200-250% utilisation or above.... the servers have a large amount of RAM which is only 30-50% according to the actual OS tools....
I performed a test on a new server, memory reported perfectly... then I installed Domino 6.5 and then after a reboot it started to report these odd amounts....
Only got 2 servers at my location out of 30+ but it would be nice to resolve this issue.
Martin J. Hamilton... lost in a sea of snmp...
Find more posts tagged with
Accepted answers
All comments
Yogibear
Hi there,
I dont know if it helps but a Domino 6 version has a memory leak issue where is constantly leaks until the server crashes. I believe it was V6.02, and I think that it is rectified in version V6.03....from your message it looks as though this may be a monitoring issue....
Cheers
Adam
mjhamilton
actually running 6.5 which has none of these issues.... this is something that Notes does to the snmp mibs on the W2K SP4 box..... not a leak..
anyone got more ideas ???????
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
