Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Switch Reboots - Report
pshankland
I have a problem at the moment with one of our switches rebooting every now-and-then. I have Orion set-up to Email when this happens but I was wondering if and how I could create a report to show when then switch rebooted.
Any suggestions?
Thanks.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
You can create a Reboot report with Orion Report Writer.
You query the event log & can display the date & time of the reboot contained in the message.
-=Cheers=-
NG
pshankland
Thanks but not quite what I wanted. That report would show the last time a device rebooted when what I need is something like the following:
Device A Rebooted on 10th October at 14:00
Device A Rebooted on 9th October at 14:00
Device A Rebooted on 5th September at 01:00
So instead of just the last time a device rebooted, I need a report showing all the reboots the device has had.
Thanks.
chris.conway
What NG suggested would do what you want.
You need to filter the Events table in Orion and show everything where node=your switch and event type=reboot
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
