Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Does ORION 8 poll serially or parrallel?
FormerMember
I am trying to figure out what the real world scalability is with an orion 8 server. If i want to poll 3000 servers and collect 35 OID counters from each server and have 5 min intervals, will orion blow up?
I am trying to figure out if ORION polls each device sequentially or does it do all of them at once or in batches, etc? Any detailed info on this would be greatly appreciated.
J
Find more posts tagged with
Accepted answers
All comments
FormerMember
I am not sure if I asked this question wrong or maybe just nobody knows. If someone could steer me in the right direction that would be super helpful.. Thanks all,
JD
Network_Guru
I did a search on Polling Elements & found the following posts & info relating to your question:
www4.solarwinds.net/.../topic.asp
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
FormerMember
You have two options to help scale as well. First, there's an add-on called 'Polls Per Second Tuning' that will help adjust your server to exactly many threads need to be used for the amount of interfaces/nodes you have. It even suggests optimal settings for you. Second, you can always add additional polling engines if you end up scaling to a huge number. For the most part though, my poller has never caused me concern (my IPS unit hates it, but i'm okay with that). Its the website and the NetFlow collector that seems to chew up our procs.
To answer the direct question though, it polls in parallel. You can see this by looking at the Polling Status under the file menu in the Performance monitor app. It will show how many polls are still out and how far along you are in a polling cycle.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
