Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Reboot Active Alerts
BakerD
I am running the eval ver of NPM7 and I have 2 active reboot alerts that have not gone away. One is a server and one is a router. It has been more than 12 hours and both devices are up and running. How do I clear these?
Find more posts tagged with
Accepted answers
All comments
iunderwo
You need to disable and re-enable the alerts in the system manager.
There are several other alerts that have no timeout or reset values, so once they've been set, they stay that way. A timeout value on these kinds of alerts has been requested before.
// Ian Underwood - Service Management
// Level 3 Communications
BakerD
I went into NPM and went to Active Alerts and check to temporarily disable all actions for all alerts and they have not gone away after about an hour. Is there some place else I should be looking? From what I see, the system manager and NPM are both the same program.
DonYonce
You could temporarily disable the Alert (not the actions, but the Alert itself) to reset all triggered Alerts.
Launch the System Manager
Select "Alerts" from the Toolbar
Click on the "Configure Alerts" button
Uncheck the Alert that you would like to reset
Click "Done"
All triggered alerts for the one you unchecked are now reset
Click on the "Configure Alerts" button again
Recheck the Alert to reenable it.
BakerD
Ahha, thanks got it now.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
