When going to the Alerts page /Orion/NetPerfMon/Alerts.aspx the dates of the alerts are all over the place, how can i sort them to show newest first?
It is not possible in the web interface to set the order by within the alerts page.
Note the Active Alerts resource lists the alerts by chronological order.
Feature Request: It would be a worthwhile feature to provide on this page as in others the column header as a click able order by.
Yes you can change the order that alerts are displayed I used this method and it works just fine in NPM 10.1 check out the link below.
