Does anybody know if it is possible to monitor with Orion NPM if a certain file is created ( or has been copied ) in some location on the disk and if that file is "found", send email?
Hi, you cannot do this with Orion NPM, however Orion APM will allow you to do this with just a few clicks.
I installed Orion APM and I can see the status of the specific file on the disk and that works ok. But, is there a possibility to send an email if that file is found there?
Of course, you use the same Advanced Alert Manager on the Orion Server that you use for alerting on things in NPM.
