Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitoring a remote network over VPN
FormerMember
Hi I currently monitor 2 networks which work great. I was also recently informed that I need to monitor another 70 interfaces over a VPN connection. I am using a Cisco VPN client version 4.8 and once I connect the VPN all other interfaces drop.
If the tunnel is up the interfaces on the Orion box stop responding. I can't reach them or even ping them. Also the website stops responding.
I tried to install a second NIC with a public IP and force the VPN client to use that. It seems like the Cisco VPN client seems to lockdown all interfaces.
Does anyone know of a way around this? Can I use a "relay Computer" to relay the messages to solarwinds? Is there a way to stop the VPN client from taking all the interfaces? Any help would be appreciated.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
This is a function of the VPN concentrator.
The VPN administrator has disabled "spilt tunneling".
This a security feature which prevents "evil doers" on the Internet from accessing your PC while you are connected to the corporate network via VPN.
You can ask your VPN Admin to allow split tunneling for the Orion server, but most likely they will say no, as you will be connecting the 3 remote network to your other 2 networks via the Orion server - not a good thing.
Installing the Cisco VPN client on your Orion Server is not recommended practice (it also installs a Firewall on your server).
Monitoring a network of 70 nodes via VPN is not reliable & prone to false alerts if there are problems with the transport network or tunnel.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
