Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Network Wide Availibility
jonchill
Is there a way of customising the network wide graphs to only use a particular group of devices based on a custom property?
The reason being we have equipment that we want to monitor but it's turned off at night so it skews the data, ideally we want to graph it against our core and edge switches as we know that these are not turned off and are on 24*7 unless there's a problem.
Jon
IT Infrastructure Manager
Pilgrim Hospital
UK
Find more posts tagged with
Accepted answers
All comments
duncan_922
I'd like to know this too. In my case I would like to have "Network Wide Graph" but for just the nodes of a specific client
DonYonce
There are a couple examples available of aggregating traffic across a group of Interfaces and displaying it on a single graph.
You can download one example from here :
ftp.solarwinds.net/.../YahooCharts.zip
This example shows how to create a set of custom charts that aggregate data.
Another method is to use a View with a custom limitation
This method works for Network Performance Monitor version 7.6 and greater.
From your Orion web site, build a new View named "Internet" and place the Network Wide charts you would like on it. Then apply a "View Limitation" to the "Internet" View. Limit the view to the list of Interfaces you would like to see combined on a single chart. Whenever you select this view, the charts will now show the aggregated data for the Interfaces you selected.
There is a thread on this topic also :
www2.solarwinds.net/.../topic.asp
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
