Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SNMP and ICMP
mick.briggs
Is there anyway to allow Orion to monitor devices only using SNMP. At this time we have our Orion Server outside of our corporate Firewalls and no access is allowed through. We aim to move the server inside and utilize the SNMP Plug on the FW. The problem is our Security dept will not allow ICMP thorough the FW,,, not even for our Orion Server. So with no ICMP enabled devices show in warning state. I have heard about the Additional Engines that can be purchased but I cannot find any info on them. Does anyone have any Ideas ?????
Cheers
Regards Mick
Find more posts tagged with
Accepted answers
All comments
iunderwo
It sounds like you've explained the reasoning enough and they still don't get it. I'd go to a higher layer of management and explain that you're looking for 1 IP to go through.
If that doesn't work, add in another NIC and do what you need to do behind the firewall with that instead.
// Ian Underwood - Service Management Specialist
// Level 3 Communications
mick.briggs
That is a solution but I would be shot
but it is apealing
Regards Mick
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
