Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
WAN Killer @ High BW
jbomar
Has anyone tried to use WAN Killer on high throughput circuits - such as OC-3 or better? I need to generate about 140 - 150 Mbps and I have a gigabit path leading up to this OC-3. The issue though is that anytime I go over about 70Mbps WAN Killer seems to get pretty odd - it will say it cannot guarantee proper results and so forth - I play with the Packet Size and so forth but I can never get over about 105Mbps at any given time ... has anyone had any luck running WAN Killer at OC-3 speeds or better?
TIA,
Jason
Find more posts tagged with
Accepted answers
All comments
bleearg13
If I were you, I'd look into using iperf to generate traffic (
dast.nlanr.net/.../)
. It's much more reliable and provides real test measurements. WAN killer is good for quick and simple traffic generation, but as you said, it's not so great at huge traffic volumes.
Josh_Stephens
Jason,
To generate high amounts of traffic, you can run multiples copies of WAN Killer either on the same machine or from multiple machines.
HTH,
Josh Stephens
SolarWinds R&D
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
