We have some config change templates that only apply to 1 specific device, is it possible to limit the use of this config change template to that 1 device, or auto select that device?
I hope that this request is possible, thanks!
If you make a compliance policy that targets the specific node you want you can then change the remediation type to Config Change Template. I strongly suggest that you have the CCT created and saved in the CCT section and maintain a version identifier and list of compliance policies it is applied to to ease the pain when the script changes.
I am gonna try this, thanks alot!
