Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Automating Node Unmanaged Status
rknight
Does anyone have a method for automatically unmanaging a Node from Orion Network Performance based on Time of Day?
Any help greatly appreciated.
Cheers
Richard Knight
Find more posts tagged with
Accepted answers
All comments
Isaac
Hi Richard,
First let me start by saying NO I DON'T.
However, if I was going to attempt this I would do so by writing a job on my SQL server to do a SQL UPDATE against the Nodes table in Orion.
The syntax of the SQL statement would look something like this:
UPDATE Nodes
SET UnManaged=1 (This is a bit value which accepts 0 or 1, 1 being unmanaged)
WHERE NodeID=[NodeID you want to unmanage]
You would then run this job when you want the device to be unmanaged and run another job with SET UnManaged=0 to manage the device again.
I hope this makes sense (I am no SQL expert).
Be fantastic.
rknight
thanks... will try to hack around with this
Cheers
Richard Knight
mjsenno
This solution makes perfect sense, I actually tried it before coming to look here but it verifies what I did.
However it creates and issue with the UnManaged var being set to 1.
Has anyone gotten this to work? Has anyone done any database updates w/o shutting the services?
martek01
It looks like it is a combination of several columns that would need to be changed:
UNMANAGED MANAGED
UnManaged -1 0
UnManagedUntil Date/Time 12:00:00 AM
Status 9 1
StatusDescription Node status is Unmanaged. Node status is Up.
These don't appear to change in concert with one another so they will all need to be set manually.
Evans Martin
Evans L. Martin - IS Analyst
Metro Govt. of Nashville, TN & Davidson County
615.862.4066 Office 615.862.6288 Fax AOL AIM: Martek01
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
