Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Logon Issue-Catalyst 6500
gbrance
Trying out the new Cirrus Configuration Management software. I built it's own account for it in TACACS. It can logon fine to Catalyst 4000 and 4500. However I am having it try to logon on our 6500's (720Sup-Hybrid) and it fails at banner. I can use the same account to telnet in fine from a Dos prompt. Has anybody else been able to get this product to work with their 6500's?
Thanks-GB
Find more posts tagged with
Accepted answers
All comments
DonYonce
gbrance,
There is a release of Cirrus that has a problem with banners on Catalysts with IOS.
I believe that has been fixed and is in testing.
gbrance
I got Cirrus to work fine on a 4500 Catalyst running IOS. I hope that the next release fixes the issue with a 6500.
Why is Cirrus requiring a logon to retrieve a config? The Network Engineering Tools can retrieve a config fine only using a read-write SNMP string. However whenever I tried to leave out a logon and only use a r/w SNMP string it would fail to D/L a config.
GB
DonYonce
Greg,
SNMP config transfer is not supported in the current Cirrus release. The Engineer's Edition tools do supoport SNMP Upload/Download of Configs, but only for Cisco devices. Cirrus is designed to support many vendor's hardware. That said, there is a good chance we will add the Cisco specific SNMP upload/download to Cirrus.
At this time, we felt multi-vendor support, config change reports, device inventory, etc were higher priorities that Cisco specific SNMP upload/download.
BryanBecker
Has the Cat Hybrid login been fixed yet? I'm have the same issue on my 6509.
BB
wills88
I come across the same situation with my Catalyst 6009
Although there is no problem with a 4503 or a 5509
greg
Would someone be willing to send me a trace of the failing login session for the cat 6500?
Send it to: Greg@solarwinds.net
P.S.
You can trace all telnet conversations in Cirrus by using the Debug Message Viewer from SysInternals, and placing a file named DebugTrace.on in the Program Files\SolarWinds\Common\ folder.
www.sysinternals.com/.../DebugView.html
Greg
greg
The new version has been posted to the download server.
Happy Downloading,
Greg
wills88
I have downloaded the 08-Nov version. After installation and do a add node. This time it says "login failed at banner"
Am I doing something wrong?
fbailey
We are still having this type of problem, although ours is giving a Timed out error.
greg
All,
Thanks so much for you help and feedback, I think most of the CatOS login issues have been solved with a patch dll that we have been sending out to individuals for testing. This patch will be in the next build, which will be going to testing shortly.
If you are still having login issues after the patch has been installed, or to get the latest version of the patch, (SWTelnet9.dll 11/11/2005, v9.0.0.1) please contact Josh@solarwinds.net.
(If an older patch is working for you, there is no need to get the latest).
Thanks again,
Greg
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
