Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Advacned Alert Trigger Help
craig999
I am trying to write an alert.. I am having problems with the trigger condition..
This is what I have got
Trigger Alert when *ANY* of the following apply
Node Status = Warning
Node Status = Down
Trigger Alert when All of the following apply
Custom_Field_Core_Network=YES
When I activate the alert, I get alerted for all devices. Not just the Custom Field Core_Network Devices.
Any help will be great
thanks
Find more posts tagged with
Accepted answers
All comments
chris.conway
Try swapping the logic around so the Core Network part is first
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
craig999
OK Will do. I will let you know how I go..
Ta
lavelanet
yeah you're logic is backwards it's that initial ANY statement you need an ALL which alerts if somethings in core AND ANY of the node status' occur
bashley
also, make sure that your conditions are nested properly.
Trigger when all
Trigger when any
Node Status = Down
craig999
OK Great, thanks for your help..
If the node goes into a warning state, and then a down state, I only get notifed of the warning. Will I need two seperate alerts to be notified of both?
larry.rice
yes, they'll need to be separate, because the alert will already be triggered/active, and therefore won't trigger again until reset (for a given object).
craig999
OK Great.. Thanks for that
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
