Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Installiing Solar Winds Orion
TonyDennis
Hello all,
I am trying having problems with the Configuration Wizard, when creating the website I am getting the following error "The wizard was unable to to register the Solarwinds COM+ Application. A possible cause is the Distributed Transaction Coordinator service is disabled"
I have verified that the service is enabled but I am not having any success. Im running Windows server 2003. Please Help!!!!!!!
Tony
Find more posts tagged with
Accepted answers
All comments
pzielins
Any luck with this issue? Im having the same problem.
Don331
Are you installing it as administrator on the local machine?
Don Barry
Aegis Mortgage Corp
Houston, TX
Network_Guru
Try re-installing Orion when you are logged into the console with admin account.
If you are using RDP to access the Orion server to do the install, then use the run command from your client:
run>
mstsc /console
Contact Solarwinds support if this does not work, as there are commands you can run to re-register services & com+ objects that may not have registered correctly.
-=Cheers=-
NG
Mithrilhall
Are you installing Orion via a terminal session?
PaulWeaver
Had this problem, turned out the IIS account was locked out (there was an failed login entry in the security log)
skaczkowski
Verify that COM+ (The IIS component) is in fact installed, you may even want to try to reinstall it...
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
