Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion Additional components-download links here
FormerMember
We have completed testing on most of the additional components. The completed tools will be posted to the customer portal soon; however, if you want them immediately, please use the following links.
Note that we have separate links for v7 and v8 versions.
Advanced Node Details Resource
ftp.solarwinds.net/.../AdvancedNodeDetails-V7.zip
ftp.solarwinds.net/.../AdvancedNodeDetails-V8.zip
DateTime Exclusions
ftp.solarwinds.net/.../DateTimeExclusions-V7.zip
Built-in for v8…
Orion Account Manager
Discontinued… Main features built-in to the Orion website. If you need to recover an Orion web account password, you can use the Database Manager to delete the old password…
Orion MOM Integration
ftp.solarwinds.net/.../Orion-MOM-Integration-V7.zip
Not ready yet for v8…
Orion Windows Event Forwarder
ftp.solarwinds.net/.../OrionWindowsEventForwarder-V7.zip
ftp.solarwinds.net/.../OrionWindowsEventForwarder-V8.zip
Polls Per Second Tuning
ftp.solarwinds.net/.../PollsPerSecondTuning-V7.exe
ftp.solarwinds.net/.../PollsPerSecondTuning-V8.exe
Orion Report Scheduler
ftp.solarwinds.net/.../ReportScheduler-Release-V7.exe
ftp.solarwinds.net/.../ReportScheduler-Release-V8.exe
Denny LeCompte
Sr. Product Manager, Orion
SolarWinds
Find more posts tagged with
Accepted answers
All comments
ds5879
Any idea when the update Wireless Management pack will be out?
FormerMember
I'm still running 7.8.5, and we are using the report scheduler, the MOM integration and the polls per second tuning
Since there are separate versions for 7 & 8, do I need to do anything special to remove the v7 components before upgrading to Orion 8.0.1 ?
dperdue
quote:
The v8 compatible version of the Wireless module has been released.
David Perdue
SolarWinds Development Team
Steve_SW
guod,
You should uninstall the additional components using their uninstallers in the uninstall group. Then you can upgrade to V8 and install the V8 version of your desired additional components.
Steve Daily
Senior Software Engineer
SolarWinds.Net
FormerMember
Thanks, Steve.
Will I have to recreate all of our scheduled reports or is there a way to export or save them so that I can just activate hem once I upgrade ?
Doug
Steve_SW
Doug,
We will not delete any reports that you made during the uninstall so they will still exist after the update. The update will move any reports in the standard location to where they need to be for V8. The only thing you may have to do is point any of your Windows scheduled tasks to the new location.
As always, you should back up any files of concern before doing any updates.
Steve Daily
SolarWinds.Net
IGFCSS.DSI
We have ORION V7 and recently contacted Solarwinds Support because we need to download ReportScheduler-Release-V7.exe. Unfortunately, our paid support ended long ago and they’ve redirected us to thwack. I’ve seen your post with URL’s to download several additional components and among them, the one we need. On the customer portal we can only access ReportScheduler-Release-V8.exe but it fails to run with Orion 7.8.
Can you help us?
Pedro Sousa
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
