Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Menu Bar and Views
kcohen1017
I've been tinkering with Menu Bars and Views to set things up in such a way as to be useful for our Help Desk. The problem is that I cannot find a way to add a new View to a Menu Bar.
I've been all over the FAQ's, KB and admin guide, and nowhere do I find this mentioned. It seems rather silly that I can create and/or modify all the Views that I want but have no way to display them.
I'm running v8.01 and see no reason to upgrade as this issue is not addressed. I've put in a ticket but have not received a response.
Anu thoughts?
Find more posts tagged with
Accepted answers
All comments
jtimes
Are you in
Advanced Mode
From the Admin screen make sure it has the following text near the top:
There are many customization features and options. We suggest you use the
Admin
section in
Basic Mode
for a while until you become familiar with customizing Views and creating User Accounts. You can change to Advanced Mode once you are comfortable with the customization options and features. You are currently in
Advanced Mode
If you are not in Advanced Mode go to Admin > Settings, and change the Allow Advanced Customization to Yes, and then click submit...
Advanced Customization allows you to create your own Menu Bars and Views.
Enabling Advanced Customization will also allow you to define a different
set of Views for each Account and set Warning and Error Thresholds for various statistics.
More Charts and Resources are also available when Advanced Customization is enabled.
Then got to:
Customize Views
Each Network Performance Monitor View can be customized. You can select which charts and device properties are displayed on each View.
Switching to Advanced Mode will enable many more available Resources that can be placed on each view. Advanced Mode also allows you to create new views.
Create the View first, and save it.
Customize MenuBars
This panel is only available in Advanced Mode. The MenuBars at the top of each page can be modified. You can add your own Menu Items and create new Menu Bars. Each Account can have a different MenuBar. Select the MenuBar for each Account from the Account Manager.
The majority of this text is directly taken from the Orion Web server Admin view.
John J. Times
kcohen1017
Yeah, the first thing I did was double-check that I'm in advanced mode. I can't add a View that I've created to a Menu Bar in Basic or Advanced mode.
Thanks for trying to help me out, though. I appreciate it.
jtimes
Not trying to sound silly here, but are you logged in as admin, or as yourself with admin rights?
whichever way you are logged in check the permissions in Allow Account to Customize Views...
Customize Menu Bars
should be the sixth option from the top left hand section of the Admin view.
Have you tried to create a new menu bar?
John J. Times
chris.conway
On your new menubar item your URL needs to look like this /NetPerfMon/View.asp?ViewName=your view eg: /NetPerfMon/View.asp?ViewName=Server Summary Then just give it a name plus an optional description and make sure you actually add it to the menubar.
kcohen1017
I'm logging in as Admin, and the Admin account does have Customize abililty.
To amplify the issue a little further, when I go into "Select Menu Items to add to xxx Menu Bar," the Views that I've created are not there.
I didn't have this issue with v7, I did quite a bit of customizing.
jtimes
I think I might see your issue... Have you tried to Add Custom Menu Item down at the bottom
I generally have two browsers open (1 for the view I want to add, the other for the custom menu)
you only have to do this once (per custom view)
Admin > Customize Menu Bars > Edit (under any menu you have already created) > + sign > Add Custom Menu Item
The /NetPerfMon/Admin/AddCustomMenuItem.asp?MenuName=XXX screen pops up.
Name it XXXX
Post the "new view" paste the custom view's URL in the URL box
Give it a good description
submit
Now it's in the Select Menu Items to add to
xxxx
Menu Bar
John J. Times
kcohen1017
That's It! Thank you, oh so much!
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
