Am I missing where to select 64 bit counters on all devcies when running a network discovery? I have only found updating 64 bit counters by editing 1 device at a time in the "manage nodes" resource.
You can do this in a bulk operation by:
Navigate to the Node Management pageSelecting all the nodes you want to make the change onClicking the "Edit Properties" buttonSelecting the SNMP checkboxSelecting the "Allow 64 bit counters" checkboxClicking submit
Please let us know if you have any problems or questions.
