Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
3Com Switch And Weird Port Speeds
deepblackmagic
I have a 3com superstack switch, and solarwinds is pulling weird values for port speeds on certain ports. It thinks one port is 40mbps and another is 80mbps when both are 100mbps, so its reporting 180% utilization sometimes during large file transfers. I tried manually entering 100000000 into the interface details port speed box, however the values presented on the website dont update eventhough the interface details window shows it as i set. I already double checked the switch configuration and the ports are set at the correct speeds, and the systems plugged into those ports see it as a 100mbit full duplex connection.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
I think 3Com does some funky stuff with the port bandwidth calcualtions.
They may consider 100mbit Full Duplex as 200mbits.
Try adjusting the interface bandwidth slider to 200mbits and see if Orion calculates correctly.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
