Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
HP ProCurve Switch, Templates
csk
Are there anyone there got a template for HP ProCurve Switch 2600 series?
Charly
Find more posts tagged with
Accepted answers
All comments
casmith32
Here ya go - I've tested with all my "recent" HP switches which all use the same OS commands... this goes for 2600, 2800, and the like... not sure about the older HP switches...I've commented out the RESET command - still not clear on what this does but it causes the login and config d/l process to take a longer time...you'll see what I mean if you do a trace on the session.
--Copyright 2005 SolarWinds.Net All rights reserved-->
<Configuration-Management Device="HP Procurve Switch" SystemOID="1.3.6.1.4.1.11.2.3.7.11">
<Commands>
<!-- leave out <Command Name="RESET" Value="terminal width 80${CRLF}terminal length 120${CRLF}"/> -->
<Command Name="Reboot" Value="boot{CRLF}y${CRLF}"/>
<Command Name="EnterConfigMode" Value="configure"/>
<Command Name="ExitConfigMode" Value="end"/>
<Command Name="Startup" Value="config"/>
<Command Name="Running" Value="running"/>
<Command Name="DownloadConfig" Value="Show ${ConfigType}"/>
<Command Name="UploadConfig" Value="${EnterConfigMode}${CRLF}${ConfigText}${CRLF}${ExitConfigMode}"/>
<Command Name="DownloadConfigIndirect" Value="copy ${ConfigType} tftp ${StorageAddress} ${StorageFilename}${CRLF}"/>
<Command Name="UploadConfigIndirect" Value="copy tftp startup-config ${StorageAddress} ${StorageFilename}${CRLF}"/>
<Command Name="EraseConfig" Value="erase startup${CRLF}y${CRLF}"/>
<Command Name="Version" Value="show version"/>
</Commands>
</Configuration-Management>
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
