Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Windows 2003 and Orion Syslog (7.7)
clerum
Has anyone got this to work? 7.7 is giving the same error that 7.6 did about not having .NET installed.
I was under the impression that .NET is intergated into the core files of 2003.
Any ideas?
Find more posts tagged with
Accepted answers
All comments
tpula
I ran into the same issue today. I unselected the Syslog service so I could complete the upgrade. I then called tech support. They instructed me on how to force the syslog service installation from the command line. No need to download any updates from Microsoft.
Todd ***
Network Engineer - CCNA/CCDA/CCNP
The Stanley Works
BK
OK, I think I know the answer to this one now.
You have terminal services installed.
When Terminal Services is installed on 2003, it is always in Application Mode. Terminal Service Administration mode was replace with Remote Deskop.
Terminal Service will alter some key environmental variables to help protect the Windows\System32 directory.
If you run the following command
change user /install
This will put Terminal Service into install mode and put the environmental variables back to where the .NET framework can be found. After running this command, you can then start the Wizard and it will find the .NET Framework.
To turn off install mode, run the command
change user /execute
BK
Nobody Special
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
