Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Downloading Router Configs
FormerMember
I just started using the VBS scripts to download switch and router configs.
The switch configs come down fine, and the message box says that the router configs are successfully downloaded too, but when I look at the router config files, they are all 0 Kb and if I try to open them, I get an error stating that they are corrupt or open as blank,
All my switch configs look Okay, but ALL my router configs come down as 0 k
I'm using the RW community string, but I must be missing something.
Any idea what I'm missing ?
Doug
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Do you have a TFTP ACL on your router?
What is the IP you are connecting to TFTP the config?
We set the TFTP source interface on our routers to the Loopback address.
-=Cheers=-
NG
FormerMember
A HA ! More information.
No ACL limititations for TFTP
We upgraded to EE Toolset 8 last week, and now it seems that I can't use any of the cisco tools on our production routers. I'm wondering if the old scripts no longer work with the new toolsets
The only router I can use with the Cisco tools is one of our 1841. We have at least 2 of that model, but only one is "working" both are running the same IOS - 12.3(8r)T8
The tools do work on all of our switches.
FormerMember
D' OH !
It turns out to be a issue regarding mapping the serial and ethernet addresses
once the missing routes were added all was well with the toolset AND the VBS script
We're feeling pretty silly right now
iceman
Doug
How did you resolve this?
Network_Guru
As I mentioned, it is best to use loopback addresses to manage a router.
It sounds like Doug did not have the routes for the Serial interfaces advertised into his network. The TFTP source address will be whatever interface the packet leaves to get to the TFTP server, unless you specify the source IP address to use in the router config.
-=Cheers=-
NG
Mithrilhall
What VBScripts are you using?
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
