Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Filtering Nodes (Interface captions)
Mithrilhall
I've created a custom link on our menu bar that only shows our VPN routers.
I have it setup to display any VPN routers that are 'downn' on the right side of the page. I would also like to show routers on the right side of page that have their Tunnel 'down'. Is there any way to Filter nodes by the caption of a certain interface (Tunnel) and that interfaces corresponding status?
Find more posts tagged with
Accepted answers
All comments
Seraphym
i'm having the same problem. i'd like to filter out all router within a specific ip address range and their BRI0 IF down. got no clue.
Network_Guru
Create a custom report with Orion Report Writer, including any Interface status icons you want to see, along with the interface captions (use "current node/interface status" from the report writer menu).
Then publish this report using the "Customize view" option & adding a "Report from Orion Report Writer" from the add resources menu. The report will display & refresh just as any other Orion page.
-=Cheers=-
NG
Seraphym
thx network guru. this solved the problem for me.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
