Has anyone had a problem under NCM after you integrate it with NPM and go to the node details for an item and tried to use telnet. It appears to have the same issue as NPM had. It is trying to use telnet: instead of telnet://. It still works under NPM but I cant seem to find where to modify this under NCM. Any ideas?
