Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Syslog as a service?
luiswiedemann
I have tried using the Win2k Resource Kit to make the syslog exe a service. However, everytime I try and start it, it errors out with the er msg...
Event Type: Error
Event Source: Service Control Manager
Event Category: None
Event ID: 7000
Date: 3/26/2004
Time: 4:21:13 PM
User: N/A
Computer: WS-78-01-195
Description:
The SWSyslogD service failed to start due to the following error:
The service did not respond to the start or control request in a timely fashion.
For more information, see Help and Support Center at
go.microsoft.com/.../events.asp.
Has anyone successfully made this a service? Before I started using the SW Syslog I was using the free Kiwi Syslog Daemon, whic ran as a service in the backround but I like the fact that the SW has more features and that it goes righ tinto an mdb rather than a delimited text file.
TIA
Luis
Find more posts tagged with
Accepted answers
All comments
Bryan
Here is the deal.. The Solarwinds apps do not play was with these external service programs. I have tried SRVANY.exe and others and always find a problem. What I did was put all of the programs in the startup folder including the screensaver.exe program. Then I used an adminstrative account and setup an autologin.. So if the computer is restarted, it will log in automatically, start all of the programs in the startup folder and then activate the screensaver which is password protected. It is not the prettiest solution but it is the only thing that I have found that works.. I'm not overlly worried about people gaining access to the computer, it they get by the guard with the M16, have at it=)
Lockheed Martin
Atlas V Launch Operations
Network Engineer
luiswiedemann
LOL, I met an engineer from Lockheed last Dec on a flight to FLA. Weird stuff man...much different than the banking world! Though I wouldn't mind the novelty of walking by a guard with an M16 every morning, its just a little too 1984 for me :-P. Well, the main issues right now are the fact that you have to have all of the applications open and the windows in your way, as opposed to just leaving it running in the background and attach something like crystal or something to the database file! Well thanks for the info; it will save me time trying to fight with it!
Also...what do you guys do in the way of documentation? We are a department of 4, one boss, one helpdesk person and two Admins (me being one of them). I need to get a grasp of change management and documentation standards and I am having a little bit of a hard time!!
Thanks for the reply!!
Luis
rknight
If you use a Terminal Services session to the server running the Solarwinds tools... you logon, run your tools, disconnect and voila it's kind of running in the background
Cheers
Ric Knight
robertkulp
I've used Kiwi's commercial version of syslogd and it works great. You can send it to an Access database or another ODBC database. Plus, it runs great as a service.
Robert Kulp
Information Services Mgr
Town of Smyrna - TN
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
