Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Reports / Custom Properties
FormerMember
I just finished installing V8 on my new production Orion server and just hit a fairly major snag. I went to check on my reports and none of my custom reports I created that used my custom node properties are working right.
All the select fields I had that used custom node properties are gone, and if I try to re-add them, none of my custom properties are showing up as options.
Anyone have any ideas?
Nevermind...I just answered my own issue, but I'll leave this post instead of deleting it.
I went into my custom property editor and added a new bogus property. I went back into the report writer and now everything is working...all my custom properties are showing up as expected. I went back into custom property editor, nuked the bogus property I had created and everything still looks cool.
So my guess is some table in the database somewhere that wasn't happy until I had updated it in the new version.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Here is the answer RangerTDC;
support.solarwinds.net/.../ProblemDetail.cfm
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
jtimes
That’s the dreaded update report schema... After a few upgrades it becomes second nature...
From the Orion Server
Open the Custom Property Editor
Right click on the grey area after Help
Select Customize…
On the Customize screen select Commands
Scroll down to Update Report Schemas
Left click and drag Update Report Schemas to the grey area after Help
Press the lightning bolt button
You should get a pop-up that says "Custom Properties have been added to all Report Schemas"
John J. Times
jlgugler
Thank you for the "tips", it happend the same thing here !
floyd.may
Thanks for posting this information! Your feedback helps us tremendously.
Floyd May
Software Developer
SolarWinds.Net
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
