Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Weird Alert Incident
gbrance
I am running 7.8 of Orion Performance Monitor and I have my Node set for 30/sec polling and 1-min Statistics.
I have a alert setup to send a e-mail and page when a node goes down. The alert trigger is down and the alert reset is up. However recently I recived a couple of e-mails from some nodes indicating that a alert had been reset on them to up. However I cannot find a event saying that the Node was ever down. How could a alert reset to up if a Node was never down?
THanks-GB
Find more posts tagged with
Accepted answers
All comments
Seraphym
hey gbrance,
if Orion can't reach a device, the status is changed to "warning". if the device responds in time (specified in "advanced settings -> node warning intervall"), the status is changed to "up".
take a look at your alert rule, pretty sure it says :
alert me when node goes down/up,
NOT when it's in warning state.
gbrance
I do have it setup to only send a alert on when the Node goes down and reset when the node goes up. However when I look at the events for the node there is no warning event logged under events. If the node went into warning status I would think that a warning event would be logged. If I set a alert to trigger when the Node goes into Down our Warning status will both alerts be reset when the Node goes into up status?
Thanks for your response-GB
Seraphym
hm. strange. now that you mention it... there is no event logged for these alarms. now i'm stuck too.
anyone got an idea ?
udaemen
Hello,
Have you trigered an interface or are you perhaps monitoring some tunnels? which trigger these alarms.
gbrance
The node warning was tripped on a Cisco 4507R Switch. Right now I only have the Orion Alarms setup to trigger on Nodes. It isn't that big of deal and has not happened again after the one incident.
GB
Seraphym
i'm monitoring i.e. Cisco 3548XL in the same LAN segment. sometimes they generate an UP-alarm without sending any DOWN-notice or events.
strange behaviour.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
