Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
New network with Solarwinds
paulfoel
I notice that when you first start to use Solarwinds there is a fair bit of manual work that needs to be done.
For instance, even though you can discover nodes with the discovery manager, you then need to create a new map and drag the nodes onto it.
Then you need to decide what icons to use, add a label, draw and configure the network links etc.
Is this normal?
Seems OK for a static network where everything is fixed but not so sure its much good for a changing network?
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Compared to other NM software, Orion is a snap to setup, especially for alerting & reporting.
As for creating maps, that's a manual process that you must stay on top of if your network is constantly changing.
-=Cheers=-
NG
bleearg13
One thing that would be really great, in the future after custom MIB support is added
, is for Orion to not only grab the IPs of interfaces, but also the MAC addresses connected to each Ethernet port. The Map Maker could then be used to automatically create a network map based upon the gathered MAC and IP topology. It could be set on a schedule, say once per day or week, to rediscover and reconfigure the map.
There are products out there like this, and we almost purchased one, but our budget got re-evaluated and the cash was invested elsewhere.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
