Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Custom Reports
BakerD
I have setup some custom reports and I have run into something I am not sure how to do or even if it can be done. I did a Server Availability report and it shows the average availability over the last 30 days. It is broken down by office and also grouped that way which I did by using fields I created in custom properties. Now what I would like to do is sum all the servers in an office and get an average percentage value which I can then have an Average Availability of a whole office and compare my other offices.
Can any help and if so, try and be as specific as you can, I just started working with the report writer today and don't know a lot about it.
Sample:
..........Node.........Average Availability
Office A
..........Server1.............99.80%
..........Server2.............99.99%
..........Server3.............97.00%
Office Average................98.93%
Office B
..........Server1.............98.00%
..........Server2.............99.00%
..........Server3............100.00%
Office Average................99.00%
And so on............
Dots were put in just to help with formatting on this post.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
I'd suggest you create a separate report for each Office location.
Create a filter for each Office, based on the Office name and server name (create a custom property for the servers,
if necessary, using the custom property editor).
Under select fields, create a single entry for "Field - availability - sort * Function: average"
This will then sum up all the filtered objects into one total for that Office.
-=Cheers=-
NG
BakerD
Great, thanks, that is doing what I want in a way. It would have been nice to have it all on one sheet, but at least I have it.
This brings up another question though. If my link to an office goes down, then that is going to affect the availability percentages of the servers in that office correct? I am guessing it would since if the link was down, NPM would not know if the server was still up or not and would look down do it.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
