Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Orion V7 - Remote Console
neillowe
I currently use the solarwind toolset but we are looking at a management package and I have thought of Orion. The team I work in is based in the US and UK. We need something that can be accessed by all for all functions. Does Orion V7 support a remote console for the Map maker etc. or are there still some functions where you need to be in front of the console.
Any comments would be appreciated.
Neil Lowe
Find more posts tagged with
Accepted answers
All comments
Network_Guru
See the following post:
www2.solarwinds.net/.../topic.asp
Mapmaker V7 works better with RDP now than V6.4 did, but still not 100%.
-=Cheers=-
NG
iunderwo
Depending on what kind of function you're looking at, it might be easier to do any of the console work via Remote Desktop. The only problem I'm aware of is the 8-bit video limition with Win2k servers. This might not be an issue with the Win2k3 Server.
The remote manager is a per-seat license, I believe, which would make it impractical for wide deployment, which would make RDP your best bet.
// Ian Underwood - Service Management
// Level 3 Communications
BryanBecker
Can someone confirm this on a Win2K3 server?
rix
Good Stuff:
DameWare Mini Remote Control
http://www.dameware.com
all kinds of options, much better than any terminal services
charpham
Just thought I would chime in here.. to plug for the product my company develops... Symantec PcAnywhere...
Also, you don't have the issue with the 8-bit video limiation as you do with temincal services
FrederickRojas
I've been using Orion for about a year now and had some issues with Remote Desktop. I started using VNC a few months back and haven't had any issues since.
Frederick Rojas
Senior Network Engineer, LCI
kreischl
Definately VNC. I use VNC for my Linux, Windows and Netware boxes.
pcanywhere is too slow!
Network_Guru
I wasn't going to say it, but now that it has been said; PCanywhere is painful to use, afer having used RDP. Over a 60ms latency e100 link it takes 2-4 seconds for anything to refresh on the screen. RDP is just like being there.
I use RDP now for modding all my maps.
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
