When I drilldown on our map the location in Denver shows Yellow. Yet when I drilldown on it everyobject is Green.
How do I correct this?
Check the Status setting for the Denver map. You might just want to change the Status slider under Map Properties to something else, save the map, reopen it and change the Status slider back to 100% and see if that helps on the main map.
That was it. I had a server on the map that had deleted. For some reason the color did not change but when you rolled over the object it showed missing.
