Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Request: Removing "Average" from the 95th chart
peng
Is it possible to remove the word "Average" from the 95th % chart? 95th % does not use averages.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
See this post:
www4.solarwinds.net/.../topic.asp
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
peng
Thanks for the reply, though the post does not have the exact answer to my question. I just want to remove the word 'average' from 95th percentile report on the bottom of the chart
Mithrilhall
My suggestion would be to contact support and ask them to send you a custom 'chart.asp' page since it looks like that is the page that creates the charts...but that's just a guess.
peng
Actually I did contact SW support, but they did not have the solution and suggested me to try the forum in the hope that some SW developer will notice and implement some solution. So here I am.
bpalma
It isn't something that Chart.asp does. It is a function within OrionNPMWeb.dll from the install directory. You will definitely need someone at Solarwinds to make that change for you.
Bob
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
