Hi:
How could I increase my SNMP knowledgements ?
I already don't have necessary expertise to work with mibs, oid's, rfc's , universal device pollers, etc.
I suggest reading some of Josh's guides here:
http://www.solarwinds.com/geek/geekguides/
Here's a bunch of snmp books on amazon:
http://www.amazon.com/SNMP-Management-Sidnie-M-Feit/dp/0070203598/ref=sr_1_2?ie=UTF8&qid=1249921750&sr=1-2
Good luck... the more you work with it... the easier it gets :}
You can't usually go wrong with O'Reilly:
oreilly.com/.../9780596000202
Or, if you're in the UK, I can highly recommend Kenson's Solarwinds training courses.
