Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Renamed server, now no devices in Manager
dsullinger
I had to rename my server, once I did this and tried to open the web page, it said I had to run the wizard again. Once completed, the Orion home page opened fine, but now when I open System Manager, it ask which polling engine I want to use. The old server name is in red and the new server name is in black. It doesn't matter which one I select, there are no nodes in System maanger once it opens.
How can I fix this?
REPLY - Ok, since I couldn't reply to my own message, I'll just add on here at the bottom. I found a self solution, I used the "Polling Engine Load Balancer" and moved the nodes over to the new polling engine.
Find more posts tagged with
Accepted answers
All comments
Network_Guru
Just be aware that any alerts you have setup will no longer be working until you move
them to the new server as well. You can do this by running a custom query in the database manager. Solarwinds support can walk you through this, or you can search these
forums for the query to run (I posted it several months ago).
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
