I would like to use information that CatTools pulls when it does a show version on Cisco equipment. I want to use it to determine if a device needs to be upgraded or not. Is there anyway to pull this information and use it will I have to run the command myself and tear it apart for what I need. This would make my life easier if I can use the information that it's already pulled. By using the show version I can determine the IOS and also the device model. I can then have a script upgrade accordingly to the device model.
